unconfigure stacking alternate-ip-address
unconfigure stacking {node-address node_address | slot slot_number} alternate-ip-address
Description
Removes the configured alternate management IP address from the specified node.
If no node is specified, the alternate management IP address is removed from every node. The change takes effect immediately for all nodes operating in stacking mode.
Syntax Description
node_address
Specifies the MAC address of a node in the stack. To view the MAC addresses for all nodes in a stack, enter the show stacking command.
slot_number
Specifies the slot number of the target active node. To view the slot numbers, enter the show stacking command.
Default
N/A.
Usage Guidelines
Run this command from any node.
To unconfigure stacking alternate-ip-address on a node:
unconfigure stacking node-address 00:04:96:26:6b:ed alternate-ip-address
To unconfigure the stacking alternate IP address configured on the active node in slot 4:
unconfigure stacking slot 4 alternate-ip-address
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available with all licenses and platforms that support the SummitStack feature. For information about which licenses and platforms support the SummitStack feature, see the Switch Engine v33.1.1 Licensing Guide document.
